inria-00502473, version 1
Signing the Unsigned: Robust Surface Reconstruction from Raw Pointsets
Patrick Mullen a, 1Fernando De Goes
a, 1Mathieu Desbrun
a, 1David Cohen-Steiner
2Pierre Alliez
2
Computer Graphics Forum 29, 5 (2010) 1733-1741
Résumé : We propose a modular framework for robust 3D reconstruction from unorganized, unoriented, noisy, and outlierridden geometric data. We gain robustness and scalability over previous methods through an unsigned distance approximation to the input data followed by a global stochastic signing of the function. An isosurface reconstruction is finally deduced via a sparse linear solve. We show with experiments on large, raw, geometric datasets that this approach is scalable while robust to noise, outliers, and holes. The modularity of our approach facilitates customization of the pipeline components to exploit specific idiosyncracies of datasets, while the simplicity of each component leads to a straightforward implementation.
- a – Caltech
- 1 : Computer Science Department (CS CALTECH)
- California Institute of Technology
- 2 : GEOMETRICA (INRIA Sophia Antipolis / INRIA Saclay - Ile de France)
- INRIA
- Collaboration : INRIA associate team with Caltech
- Domaine : Informatique/Géométrie algorithmique
- Mots-clés : surface reconstruction – noise robust – outlier robust
- inria-00502473, version 1
- http://hal.inria.fr/inria-00502473
- oai:hal.inria.fr:inria-00502473
- Contributeur : Pierre Alliez
- Soumis le : Jeudi 15 Juillet 2010, 09:39:20
- Dernière modification le : Jeudi 15 Juillet 2010, 10:45:19
Documents associés
Exporter
