On the Rates of Convergence of the Wireless Multi-access Interference Distribution to the Normal Distribution - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
It is of prime importance to reveal the structure of wireless multi-access interference distributions to compute many performance bounds and metrics for wireless networks such as transmission capacity, outage probability and bit-errorrate. However, at the present, there are no closed form expressions for the multi-access interference distributions in wireless networks apart from a very special case. This paper presents a principled methodology towards the resolution of this bottleneck by establishing rates of convergence of the multi-access interference distribution to a Gaussian distribution for any given bounded power-law decaying path-loss function G.
p569-inaltekin.pdf (576.69 Ko) Télécharger le fichier
inria-00503044 , version 1 (16-07-2010)
  • HAL Id : inria-00503044 , version 1
Hazer Inaltekin, Stephen V. Hanly. On the Rates of Convergence of the Wireless Multi-access Interference Distribution to the Normal Distribution. WiOpt'10: Modeling and Optimization in Mobile, Ad Hoc, and Wireless Networks, May 2010, Avignon, France. pp.569-574. ⟨inria-00503044⟩
Collections
WIOPT2010
54 Consultations
53 Téléchargements
