Throughput-Delay-Reliability Tradeoff in Ad Hoc Networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rahul Vaze
  • Fonction : Auteur
  • PersonId : 874037
Delay-reliability (D-R), and throughput-delayreliability (T-D-R) tradeoffs in an ad hoc network are derived for single hop and multi-hop transmission with automatic repeat request (ARQ) on each hop. The delay constraint is modeled by assuming that each packet is allowed at most D retransmissions end-to-end, and the reliability is defined as the probability that the packet is successfully decoded in at most D retransmissions. The throughput of the ad hoc network is characterized by the transmission capacity, which is defined to be the maximum allowable density of transmitting nodes satisfying a per transmitter receiver rate, and an outage probability constraint, multiplied with the rate of transmission and the success probability. Given an end-to-end retransmission constraint of D, the optimal allocation of the number of retransmissions allowed at each hop is derived that maximizes a lower bound on the transmission capacity. For equidistant hops equally distributing the total retransmission constraint among all the hops is optimal. Optimizing over the number of hops, single hop transmission is shown to be optimal for maximizing a lower bound on the transmission capacity in the sparse network regime.
p575-vaze.pdf (440.85 Ko) Télécharger le fichier
inria-00503049 , version 1 (16-07-2010)
  • HAL Id : inria-00503049 , version 1
Rahul Vaze. Throughput-Delay-Reliability Tradeoff in Ad Hoc Networks. WiOpt'10: Modeling and Optimization in Mobile, Ad Hoc, and Wireless Networks, May 2010, Avignon, France. pp.575-580. ⟨inria-00503049⟩
Collections
WIOPT2010
41 Consultations
189 Téléchargements
