A Stochastic Geometry Model for the Best Signal Quality in a Wireless Network - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Minh Nguyen Van
  • Fonction : Auteur
  • PersonId : 874038
François Baccelli
In a wireless network composed of randomly scattered nodes, the characterization of the distribution of the best signal quality received from a group of nodes is of primary importance for many network design problems. In this paper, using shot noise models for the interference field, we develop a framework for analyzing this distribution. We first identify the joint distribution of the interference and the maximum signal strength. We then represent the best signal quality as a function of these two quantities. Particular practical scenarios are also analyzed in which explicit expressions are obtained.
p581-nguyen.pdf (377.1 Ko) Télécharger le fichier
inria-00503054 , version 1 (16-07-2010)
  • HAL Id : inria-00503054 , version 1
Minh Nguyen Van, François Baccelli. A Stochastic Geometry Model for the Best Signal Quality in a Wireless Network. WiOpt'10: Modeling and Optimization in Mobile, Ad Hoc, and Wireless Networks, May 2010, Avignon, France. pp.465-471. ⟨inria-00503054⟩
173 Consultations
211 Téléchargements
