Insertion of 3D-Primitives in Mesh-Based Representations: Towards Compact Models Preserving the Details - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Image Processing Année : 2010
We propose an original hybrid modeling process of urban scenes that represents 3-D models as a combination of mesh-based surfaces and geometric 3-D-primitives. Meshes describe details such as ornaments and statues, whereas 3-D-primitives code for regular shapes such as walls and columns. Starting from an 3-D-surface obtained by multiview stereo techniques, these primitives are inserted into the surface after being detected. This strategy allows the introduction of semantic knowledge, the simplification of the modeling, and even correction of errors generated by the acquisition process. We design a hierarchical approach exploring different scales of an observed scene. Each level consists first in segmenting the surface using a multilabel energy model optimized by -expansion and then in fitting 3-D-primitives such as planes, cylinders or tori on the obtained partition where relevant. Experiments on real meshes, depth maps and synthetic surfaces show good potential for the proposed approach.
tip_2010a.pdf (2.17 Mo) Télécharger le fichier
inria-00503145 , version 1 (28-01-2013)
Florent Lafarge, Renaud Keriven, Mathieu Brédif. Insertion of 3D-Primitives in Mesh-Based Representations: Towards Compact Models Preserving the Details. IEEE Transactions on Image Processing, 2010, 19 (7), pp.1683-1694. ⟨10.1109/TIP.2010.2045695⟩. ⟨inria-00503145⟩
545 Consultations
927 Téléchargements
