Integrating Legacy Systems with MDE - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Integrating several legacy software systems together is commonly performed with multiple applications of the Adapter Design Pattern in oo languages such as Java. The integration is based on specifying bi-directional translations between pairs of apis from different systems. Yet, manual development of wrappers to implement these translations is tedious, expensive and error-prone. In this paper, we explore how models, aspects and generative techniques can be used in conjunction to alleviate the implementation of multiple wrappers. Briefly the steps are, (1) the automatic reverse engineering of relevant concepts in apis to high-level models; (2) the manual definition of mapping relationships between concepts in different models of apis using an ad-hoc dsl; (3) the automatic generation of wrappers from these mapping specifications using aop. This approach is weighted against manual development of wrappers using an industrial case study. Criteria are the relative code length and the increase of automation.
CLAVREUL10a.pdf (1.49 Mo) Télécharger le fichier
inria-00504669 , version 1 (21-07-2010)
  • HAL Id : inria-00504669 , version 1
Mickael Clavreul, Olivier Barais, Jean-Marc Jézéquel. Integrating Legacy Systems with MDE. ICSE'10: Proceedings of the 32nd ACM/IEEE International Conference on Software Engineering and ICSE Workshops, 2010, Cape Town, South Africa. pp.69--78. ⟨inria-00504669⟩
195 Consultations
232 Téléchargements
