Design of a Collaborative Disaster Response Process Management System - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Jörn Franke
  • Fonction : Auteur
  • PersonId : 868174
We describe in this article a framework for disaster response process management. This framework can be used to develop information systems sup- porting those processes. It is grounded in several research approaches: literature research, case studies, end user interviews and workshops. We compare disaster response process management with business process management and argue why it is substantial different to it. Another main result of this comparison is that busi- ness process management technology, such as flexible workflow systems, are not suitable for disaster response processes. We propose an information system sup- porting disaster response processes based on our developed framework. Finally we present validation of the information system design and give outlook on our future research.
Informatique
5_jFranke_et_al_57_78.pdf (1.14 Mo) Télécharger le fichier
inria-00505195 , version 1 (22-07-2010)
  • HAL Id : inria-00505195 , version 1
Jörn Franke, François Charoy. Design of a Collaborative Disaster Response Process Management System. 9th International Conference on the Design of Cooperative Systems (COOP'2010), May 2010, Aix-En-Provence, France. ⟨inria-00505195⟩
454 Consultations
662 Téléchargements
