Effect of protonation on the electronic structure of PAH molecules - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2010
The electronic absorption spectra of isolated protonated polycyclic aromatic hydrocarbon molecules, (PAH)H+, are unknown. Recent interest in the absorption spectra of these stable closed-shell molecules arises from the hypothesis that they may be carriers of the long-known but unidentified Diffuse Interstellar Bands (DIBs) occurring in the visible to infrared spectral range (400-1300 nm). We report here the first experimental detection of the electronic spectrum of protonated naphthalene, the simplest (PAH)H+, in the 500 nm region, providing compelling spectroscopic support for the hypothesis that (PAH)H+ might indeed be carriers of the DIBs. The large protonation-induced shift in the transition energy (> 40%) from the transition of isoelectronic neutral naphthalene (312 nm) is rationalized by a charge transfer state, which is only accessible in the protonated species.
protnated_NpH_.pdf (185.9 Ko) Télécharger le fichier
inria-00505202 , version 1 (23-07-2010)
  • HAL Id : inria-00505202 , version 1
Ivan Alata, Reza Omidyan, Claude Dedonder, Michel Broquier, Otto Dopfer, et al.. Effect of protonation on the electronic structure of PAH molecules. 2010. ⟨inria-00505202⟩
203 Consultations
301 Téléchargements
