LiFTinG: Lightweight Freerider-Tracking Protocol in Gossip - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper presents LiFTinG, the first protocol to detect freeriders, including colluding ones, in gossip-based content dissemination systems with asymmetric data exchanges. LiFTinG relies on nodes tracking abnormal behaviors by cross-checking the history of their previous interactions, and exploits the fact that nodes pick neighbors at random to prevent colluding nodes from covering up each others' bad actions. We present a methodology to set the parameters of LiFTinG based on a theoretical analysis. In addition to simulations, we report on the deployment of LiFTinG on PlanetLab. In a 300-node system, where a stream of 674 kbps is broadcast, LiFTinG incurs a maximum overhead of only 8% while providing good results: for instance, with 10% of freeriders decreasing their contribution by 30%, LiFTinG detects 86% of the freeriders after only 30 seconds and wrongfully expels only a few honest nodes.
paper.pdf (334.32 Ko) Télécharger le fichier
inria-00505268 , version 1 (15-03-2013)
Rachid Guerraoui, Kévin Huguenin, Anne-Marie Kermarrec, Maxime Monod, Swagatika Prusty. LiFTinG: Lightweight Freerider-Tracking Protocol in Gossip. 11th ACM/IFIP/USENIX International Middleware Conference (MIDDLEWARE), Nov 2010, Bangalore, India. ⟨10.1007/978-3-642-16955-7_16⟩. ⟨inria-00505268⟩
707 Consultations
180 Téléchargements
