ESTIMATING THE PROBABILITY OF FALSE ALARM FOR A ZERO-BIT WATERMARKING TECHNIQUE - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
Assessing that a probability of false alarm is below a given significance level is a crucial issue in watermarking. We pro- pose an iterative and self-adapting algorithm which estimates very low probabilities of error. Some experimental investiga- tions validates its performance for a rare detection scenario where there exists a close form formula of the probability of false alarm. Our algorithm appears to be much quicker and more accurate than a classical Monte Carlo estimator. It even allows the experimental measurement of error exponents.
ExpAssessment.pdf (336.74 Ko) Télécharger le fichier
inria-00505877 , version 1 (26-07-2010)
  • HAL Id : inria-00505877 , version 1
Teddy Furon, Cyrille Jégourel, Arnaud Guyader, Frédéric Cérou. ESTIMATING THE PROBABILITY OF FALSE ALARM FOR A ZERO-BIT WATERMARKING TECHNIQUE. IEEE International Conference on Digital Signal Processing, Jul 2009, Santorini, Greece. ⟨inria-00505877⟩
316 Consultations
242 Téléchargements
