WORST CASE ATTACKS AGAINST BINARY PROBABILISTIC TRAITOR TRACING CODES - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
This article deals with traitor tracing which is also known as active fingerprinting, content serialization, or user forensics. We study the impact of worst case attacks on the well-known Tardos binary prob- abilistic traitor tracing code, and especially its optimum setups re- cently advised by Amiri and Tardos, and by Huang and Moulin. This paper assesses that these optimum setups are robust in the sense that a discrepancy between the foreseen numbers of colluders and the its actual value doesn't spoil the achievable rate of a joint decoder. On the other hand, this discrepancy might have a dramatic impact on a single decoder. Since the complexity of the today's joint decoder is prohibitive, this paper mitigates the interest of the optimum setups.
worst_case_conf.pdf (115.1 Ko) Télécharger le fichier
inria-00505886 , version 1 (26-07-2010)
  • HAL Id : inria-00505886 , version 1
Teddy Furon, Luis Pérez-Freire. WORST CASE ATTACKS AGAINST BINARY PROBABILISTIC TRAITOR TRACING CODES. IEEE International Workshop on Information Forensics and Security, Dec 2009, London, United Kingdom. ⟨inria-00505886⟩
178 Consultations
137 Téléchargements
