QoS Ad Hoc Routing Protocol Analysis in Civil Safety Context - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2010
In this paper, we have conducted an investigation of quality of service (QoS) approaches supporting a ad hoc routing protocol in civil safety context. We have proposed different schemes of the QoS path selection among multiple paths in order to find the most suitable in our context. We analyze an influence of the route path information and per-hop information. This performance analysis shows us which method is adequate in civil safety environment.
RR-7358.pdf (463.66 Ko) Télécharger le fichier
inria-00506968 , version 1 (29-07-2010)
  • HAL Id : inria-00506968 , version 1
Sylwia Romaszko, Jean Carle. QoS Ad Hoc Routing Protocol Analysis in Civil Safety Context. [Research Report] RR-7358, INRIA. 2010. ⟨inria-00506968⟩
93 Consultations
118 Téléchargements
