On the Roth and Ruckenstein equations for the Guruswami-Sudan algorithm - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
In 2000 Roth and Ruckenstein proposed an extended key equation for solving the interpolation step in the Sudan decoding algorithm. Generalizing their idea, a sequence of key equations for the Guruswami-Sudan (GS) algorithm, which is able to list decode a Reed-Solomon code with arbitrary rate, is derived. This extension allows a reduction of the number of equations and therefore a reduction of the algorithmpsilas complexity. Furthermore, we indicate how to adapt the fundamental iterative algorithm for block Hankel matrices and thus solving the GS-interpolation step efficiently.
ExtendedEKE.pdf (116.9 Ko) Télécharger le fichier
inria-00509209 , version 1 (10-08-2010)
Daniel Augot, Alexander Zeh. On the Roth and Ruckenstein equations for the Guruswami-Sudan algorithm. Information Theory, 2008. ISIT 2008. IEEE International Symposium on, Jul 2008, Toronto, Canada. pp.2620-2624, ⟨10.1109/ISIT.2008.4595466⟩. ⟨inria-00509209⟩
Collections
INRIA INRIA2
145 Consultations
220 Téléchargements
