A three round authenticated group key agreement protocol for ad hoc networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Pervasive and Mobile Computing Année : 2007
Group Key Agreement (GKA) protocols enable the participants to derive a key based on each one's contribution over a public network without any central authority. They also provide efficient ways to change the key when the participants change. While some of the proposed GKA protocols are too resource consuming for the constraint devices often present in ad hoc networks, others lack a formal security analysis. In this paper, we propose a simple, efficient and secure GKA protocol well-suited to ad hoc networks and present results of our implementation of the same in a prototype application.
PMC-D-05-00043.pdf (822.9 Ko) Télécharger le fichier
inria-00509215 , version 1 (10-08-2010)
Daniel Augot, Raghav Bhaskar, Valérie Issarny, Daniele Sacchetti. A three round authenticated group key agreement protocol for ad hoc networks. Pervasive and Mobile Computing, 2007, 3 (1), pp.36-52. ⟨10.1016/j.pmcj.2006.07.001⟩. ⟨inria-00509215⟩
Collections
INRIA INRIA2
122 Consultations
237 Téléchargements
