Newton's identities for minimum codewords of a family of alternant codes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 1995
Daniel Augot
  • Fonction : Auteur
  • PersonId : 833459
We are able to define minimum weight codewords of some alternant codes in terms of solutions to algebraic equations. Particular attention is given to the case of the classical Goppa codes. Grobner bases are used to solve the system of algebraic equations
alternant-algsys.pdf (89.76 Ko) Télécharger le fichier
inria-00509424 , version 1 (12-08-2010)
Daniel Augot. Newton's identities for minimum codewords of a family of alternant codes. 1995 IEEE International Symposium on Information Theory, Sep 1995, Whistler, Canada. pp.349, ⟨10.1109/ISIT.1995.550336⟩. ⟨inria-00509424⟩
Collections
INRIA INSMI INRIA2
125 Consultations
145 Téléchargements
