Efficient Glossy Global Illumination with Interactive Viewing
The ability to perform interactive walkthroughs of global illumination solutions including glossy effects is a chal-lenging open problem. In this paper we overcome certain limitations of previous approaches. We first introduce a novel, memory- and compute-efficient representation of incoming illumination, in the context of a hierarchical radiance clustering algorithm. We then represent outgoing radiance with an adaptive hierarchical basis, in a man-ner suitable for interactive display. Using appropriate refinement and display strategies, we achieve walkthroughs of glossy solutions at interactive rates for non-trivial scenes. In addition, our implementation has been developed to be portable and easily adaptable as an extension to existing, diffuse-only, hierarchical radiosity systems. We present results of the implementation of glossy global illumination in two independent global illumination systems.
Stamminger_2000_EGG.pdf (598.56 Ko)
Télécharger le fichier
Format : Figure, Image
