Instant Visibility - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2001
Instant Visibility
Peter Wonka
  • Fonction : Auteur
Michael Wimmer
  • Fonction : Auteur
We present an online occlusion culling system which computes visibility in parallel to the rendering pipeline. We show how to use point visibility algorithms to quickly calculate a tight potentially visible set (PVS) which is valid for several frames, by shrinking the occluders used in visibility calculations by an adequate amount. These visibility calculations can be performed on a visibility server, possibly a distinct computer communicating with the display host over a local network. The resulting system essentially combines the advantages of online visibility processing and region-based visibility calculations, allowing asynchronous processing of visibility and display operations. We analyze two different types of hardware-based point visibility algorithms and address the problem of bounded calculation time which is the basis for true real-time behavior. Our results show reliable, sustained 60 Hz performance in a walkthrough with an urban environment of nearly 2 million polygons, and a terrain flyover.
WWS01.pdf (1.21 Mo) Télécharger le fichier
WWS01.mpg (32.37 Mo) Télécharger le fichier
WWS01_divx_720.avi (24.77 Mo) Télécharger le fichier
Format : Figure, Image
Format : Autre
Format : Autre
inria-00510048 , version 1 (17-08-2010)
  • HAL Id : inria-00510048 , version 1
Peter Wonka, Michael Wimmer, François X. Sillion. Instant Visibility. Eurographics, Eurographics, 2001, Manchester, United Kingdom. ⟨inria-00510048⟩
135 Consultations
301 Téléchargements
