Subdivision Curve Primitives: a New Solution for Interactive Implicit Modeling - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2001
To remain an attractive model, skeleton-based implicit surfaces have to allow the design and display of shapes at interactive rates. This paper focuses on surfaces whose skeletons are graphs of interconnected curves. We present subdivision-curve primitives that rely on convolution for generating bulge-free and crease-free implicit surfaces. These surfaces are efficiently yet correctly displayed using local meshes around each curve that locally overlap in blending regions. Subdivision-curve primitives offer a practical solution to the unwanted-blending problem that ensures $C^1$ continuity everywhere. Moreover, they can be used to generate representations at different levels of detail, enabling the interactive display of at least a coarse version of the objects, whatever the performance of the workstation.
implicitSubCurves.pdf (350.59 Ko) Télécharger le fichier
crossRose.tif (216.21 Ko) Télécharger le fichier
kangourou.tif (330.33 Ko) Télécharger le fichier
lips.tif (203.8 Ko) Télécharger le fichier
lod4.tif (235.68 Ko) Télécharger le fichier
snake.tif (249.64 Ko) Télécharger le fichier
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
inria-00510051 , version 1 (17-08-2010)
  • HAL Id : inria-00510051 , version 1
Marie-Paule Cani, Samuel Hornus. Subdivision Curve Primitives: a New Solution for Interactive Implicit Modeling. Shape Modeling International, IEEE, 2001, Gênes, Italy. ⟨inria-00510051⟩
155 Consultations
315 Téléchargements
