Animating Lava Flows - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 1999
Animating lava flowing down the slopes of a volcano brings several challenges: modeling the mechanical features of lava and how they evolve over time depending on temperature; computing, in a reasonable time, the interactions inside the flow, and between the flow and a complex terrain data-base; and lastly, rendering the visual aspect of the flow. The methods described rely on smoothed particles governed by a state equation for animating the flow. We adapt this model to the animation of lava by linking viscosity to a temperature field and by simulating heat transfers. We propose particular data-structures that lead to linear computational time with respect to the number of particles. Lastly, we study a model based on a color-and-displacement procedural texture controlled by the flow for the realistic rendering of lava.
gi99.pdf (383.22 Ko) Télécharger le fichier
lava_render.mpg (1000.3 Ko) Télécharger le fichier
petiteLave.mov (1.9 Mo) Télécharger le fichier
Format : Figure, Image
Format : Autre
Format : Autre
inria-00510066 , version 1 (17-08-2010)
  • HAL Id : inria-00510066 , version 1
Dan Stora, Pierre-Olivier Agliati, Marie-Paule Cani, Fabrice Neyret, Jean-Dominique Gascuel. Animating Lava Flows. Graphics Interface (GI'99) Proceedings, 1999, Kingston, Ontario, Canada. pp.203--210. ⟨inria-00510066⟩
1058 Consultations
1561 Téléchargements
