Efficient Glossy Global Illumination with Interactive Viewing - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 1999
The ability to perform interactive walkthroughs of global illumination solutions including glossy effects is a challenging open problem. In this paper we overcome certain limitations of previous approaches. We first introduce a novel, memory- and compute-efficient representation of incoming illumination, in the context of a hierarchical radiance clustering algorithm. We then represent outgoing radiance with an adaptive hierarchical basis, in a manner suitable for interactive display. Using appropriate refinement and display strategies, we achieve walkthroughs of glossy solutions at interactive rates for non-trivial scenes. In addition, our implementation has been developed to be portable and easily adaptable as an extension to existing, diffuse-only, hierarchical radiosity systems. We present results of the implementation of glossy global illumination in two independent global illumination systems.
Stamminger_1999_EGG.pdf (120.52 Ko) Télécharger le fichier
Stamminger_1999_EGG.mov (21.91 Mo) Télécharger le fichier
Format : Autre
inria-00510070 , version 1 (17-08-2010)
Marc Stamminger, Annette Scheel, Xavier Granier, Frederic Perez-Cazorla, George Drettakis, et al.. Efficient Glossy Global Illumination with Interactive Viewing. Proceedings of Graphics Interface, Jun 1999, Kingston, Ontario, Canada. pp.50-57, ⟨10.20380/GI1999.08⟩. ⟨inria-00510070⟩
169 Consultations
215 Téléchargements
