Interactive Rendering using the Render Cache - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 1999
Interactive rendering requires rapid visual feedback. The render cache is a new method for achieving this when using high-quality pixel-oriented renderers such as ray tracing that are usually considered too slow for interactive use. The render cache provides visual feedback at a rate faster than the renderer can generate complete frames, at the cost of producing approximate images during camera and object motion. The method works both by caching previous results and reprojecting them to estimate the current image and by directing the renderer's sampling to more rapidly improve subsequent images. Our implementation demonstrates an interactive application working with both ray tracing and path tracing renderers in situations where they would normally be considered too expensive. Moreover we accomplish this using a software only implementation without the use of 3D graphics hardware.
WalterEGWR99.pdf (259.65 Ko) Télécharger le fichier
RenderCache.mov (54.41 Mo) Télécharger le fichier
Format : Autre
inria-00510073 , version 1 (17-08-2010)
  • HAL Id : inria-00510073 , version 1
Bruce Walter, George Drettakis, Steven Parker. Interactive Rendering using the Render Cache. Rendering techniques '99 (Proceedings of the 10th Eurographics Workshop on Rendering), Jun 1999, Granada, Spain. pp.235--246. ⟨inria-00510073⟩
580 Consultations
520 Téléchargements
