A Global Illumination Solution for General Reflectance Distributions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 1991
James Arvo
  • Fonction : Auteur
Stephen Westin
  • Fonction : Auteur
Donald P. Greenberg
  • Fonction : Auteur
A general light transfer simulation algorithm for environments composed of materials with arbitrary reflectance functions is presented. This algorithm removes the previous practical restriction to ideal specular and/or ideal diffuse environments, and supports complex physically based reflectance distributions. This is accomplished by extending previous two-pass ray-casting radiosity approaches to handle non-uniform intensity distributions, and resolving all possible energy transfers between sample points. An implementation is described based on a spherical harmonic decomposition for encoding both bidirectional reflectance distribution functions for materials, and directional intensity distributions for illuminated surfaces. The method compares favorably with experimental measurements.
SAWG91.pdf (4.15 Mo) Télécharger le fichier
inria-00510145 , version 1 (17-08-2010)
  • HAL Id : inria-00510145 , version 1
François X. Sillion, James Arvo, Stephen Westin, Donald P. Greenberg. A Global Illumination Solution for General Reflectance Distributions. SIGGRAPH'91 conference proceedings, 1991, Las Vegas, United States. pp.187-196. ⟨inria-00510145⟩
184 Consultations
681 Téléchargements
