Volumetric Cell-and-Portal Generation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2003
We present an algorithm to generate a cell-and-portal decomposition of general indoor scenes. The method is an adaptation of the 3D watershed transform, computed on a distance-to-geometry sampled field. The watershed is processed using a flooding analogy in the distance field space. Flooding originates from local minima, each minimum producing a region. Portals are built as needed to avoid the merging of regions during their growth. As a result, the cell it deals with parametric curves, implicit surfaces, volumetric data and polygon soups in a unified way.
mcp.pdf (832.86 Ko) Télécharger le fichier
Format : Figure, Image
inria-00510188 , version 1 (14-10-2010)
  • HAL Id : inria-00510188 , version 1
Denis Haumont, Olivier Debeir, François X. Sillion. Volumetric Cell-and-Portal Generation. Computer Graphics Forum, 2003, Grenade, Spain. pp.303 -- 312. ⟨inria-00510188⟩
210 Consultations
1063 Téléchargements
