A Computer-Assisted Colorization Algorithm based on Topological Difference - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2006
Region-based approaches to cel painting typically use shape similarity and topology relations between regions of consecutive animation frames. This paper presents a new colorization algorithm based on topological differences defined over a hierarchical graph of adjacent regions, which allows an almost full automatic colorization process. Also this paper discusses other attributes that improve the solution of the image association problem.
BFV06.pdf (373.91 Ko) Télécharger le fichier
Format : Figure, Image
inria-00510218 , version 1 (13-10-2010)
  • HAL Id : inria-00510218 , version 1
Hedlena Bezerra, Bruno Feijo, Luiz Velho. A Computer-Assisted Colorization Algorithm based on Topological Difference. Proceedings of the Brazilian Symposium on Computer Graphics and Image Processing, 19 (SIBGRAPI), 2006, Manaus, Brazil. ⟨inria-00510218⟩
152 Consultations
278 Téléchargements
