Fast Scene Voxelization and Applications - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2006
This paper presents a novel approach that uses graphics hardware to dynamically calculate a voxel-based representation of a scene. The voxelization is obtained on run-time in the order of milliseconds, even for complex and dynamic scenes containing more than 1,000,000 polygons. The voxelization is created and stored on the GPU avoiding unnecessary data transfer. The approach can handle both regular grids and locally optimized grids that better fit the scene geometry. The paper demonstrates applications to shadow calculation, refraction simultation and shadow volume culling/clamping.
copyright ACM, 2006. This is the author's version of the work. It is posted here by permission of ACM for your personal use. Not for redistribution. The definitive version was published in Proceedings of I3D 2006
voxels05-final.pdf (1.34 Mo) Télécharger le fichier
FastVoxelization.ppt (20.14 Mo) Télécharger le fichier
dragon.avi (5.73 Mo) Télécharger le fichier
feline.avi (3.65 Mo) Télécharger le fichier
office.avi (1.7 Mo) Télécharger le fichier
principle.avi (4.68 Mo) Télécharger le fichier
reindeer.avi (16.04 Mo) Télécharger le fichier
shadows.avi (20.18 Mo) Télécharger le fichier
Format : Figure, Image
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
inria-00510221 , version 1 (13-10-2010)
  • HAL Id : inria-00510221 , version 1
Elmar Eisemann, Xavier Décoret. Fast Scene Voxelization and Applications. ACM SIGGRAPH Symposium on Interactive 3D Graphics and Games, 2006, Redwood City, United States. pp.71-78. ⟨inria-00510221⟩
494 Consultations
2481 Téléchargements
