Multipitch estimation of piano sounds using a new probabilistic spectral smoothness principle - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Audio, Speech and Language Processing Année : 2010
A new method for the estimation of multiple concurrent pitches in piano recordings is presented. It addresses the issue of overlapping overtones by modeling the spectral envelope of the overtones of each note with a smooth autoregressive model. For the background noise, a moving-average model is used and the combination of both tends to eliminate harmonic and sub-harmonic erroneous pitch estimations. This leads to a complete generative spectral model for simultaneous piano notes, which also explicitly includes the typical deviation from exact harmonicity in a piano overtone series. The pitch set which maximizes an approximate likelihood is selected from among a restricted number of possible pitch combinations as the one. Tests have been conducted on a large homemade database called MAPS, composed of piano recordings from a real upright piano and from high-quality samples.
Emiya2010.pdf (626.07 Ko) Télécharger le fichier
inria-00510392 , version 1 (18-08-2010)
Valentin Emiya, Roland Badeau, Bertrand David. Multipitch estimation of piano sounds using a new probabilistic spectral smoothness principle. IEEE Transactions on Audio, Speech and Language Processing, 2010, 18 (6), pp.1643-1654. ⟨10.1109/TASL.2009.2038819⟩. ⟨inria-00510392⟩
440 Consultations
1634 Téléchargements
