Spectral measure and approximation of homogenized coefficients - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Probability Theory and Related Fields Année : 2012
This article deals with the numerical approximation of effective coefficients in stochastic homogenization of discrete linear elliptic equations. The originality of this work is the use of a well-known abstract spectral representation formula to design and analyze effective and computable approximations of the homogenized coefficients. In particular, we show that information on the edge of the spectrum of the generator of the environment viewed by the particle projected on the local drift yields bounds on the approximation error, and conversely. Combined with results by Otto and the first author in low dimension, and results by the second author in high dimension, this allows us to prove that for any dimension $d\geq 2$, there exists an explicit numerical strategy to approximate homogenized coefficients which converges at the rate of the central limit theorem.
Gloria-Mourrat-8.pdf (305.41 Ko) Télécharger le fichier
inria-00510513 , version 1 (19-08-2010)
inria-00510513 , version 2 (22-05-2011)
Antoine Gloria, Jean-Christophe Mourrat. Spectral measure and approximation of homogenized coefficients. Probability Theory and Related Fields, 2012, 154, pp.287-326. ⟨10.1007/s00440-011-0370-7⟩. ⟨inria-00510513v2⟩
451 Consultations
264 Téléchargements
