Tissage d'Aspects Comportementaux - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2006
The notion of aspect looks promising for handling crosscutting concerns earlier in the software life-cycle, up from programming to design, analysis and even requirements. This paper proposes a technique to encapsulate and weave behaviors described as sequence diagrams in base models which contain a finite set of sequence diagrams. The weaving process is twophased. Firstly the detection phase searches parts in the base model. Secondly the composition phase builds the woven model by composing the advise in the base model for each detected part. The entire weaving process is automated and is implemented as model transformations within the Kermeta environment.
klein06b.pdf (692.38 Ko) Télécharger le fichier
inria-00511391 , version 1 (24-08-2010)
  • HAL Id : inria-00511391 , version 1
Jacques Klein, Franck Fleurey. Tissage d'Aspects Comportementaux. Langages et Modèles à Objets: LMO'06, Mar 2006, Nimes, France. ⟨inria-00511391⟩
107 Consultations
71 Téléchargements
