An algorithm for solving the discrete log problem on hyperelliptic curves - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2000
We present an index-calculus algorithm for the computation of discrete logarithms in the Jacobian of hyperelliptic curves defined over finite fields. The complexity predicts that it is faster than the Rho method for genus greater than 4. To demonstrate the efficiency of our approach, we describe our breaking of a cryptosystem based on a curve of genus 6 recently proposed by Koblitz.
euro2K.pdf (261.4 Ko) Télécharger le fichier
inria-00512401 , version 1 (30-08-2010)
Pierrick Gaudry. An algorithm for solving the discrete log problem on hyperelliptic curves. Eurocrypt, 2000, Bruges, Belgium. pp.19-34, ⟨10.1007/3-540-45539-6_2⟩. ⟨inria-00512401⟩
344 Consultations
1660 Téléchargements
