Counting points on hyperelliptic curves over finite fields - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2000
We describe some algorithms for computing the cardinality of hyperelliptic curves and their Jacobians over finite fields. They include several methods for obtaining the result modulo small primes and prime powers, in particular an algorithm à la Schoof for genus 2 using Cantor's division polynomials. These are combined with a birthday paradox algorithm to calculate the cardinality. Our methods are practical and we give actual results computed using our current implementation. The Jacobian groups we handle are larger than those previously reported in the literature.
antsIV.pdf (280.13 Ko) Télécharger le fichier
inria-00512403 , version 1 (30-08-2010)
Pierrick Gaudry, Robert Harley. Counting points on hyperelliptic curves over finite fields. ANTS-IV, 2000, Leiden, Netherlands. pp.313-332, ⟨10.1007/10722028_18⟩. ⟨inria-00512403⟩
163 Consultations
1232 Téléchargements
