An introduction to small scale reflection in Coq - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Formalized Reasoning Année : 2010
This tutorial presents the Ssreflect extension to the Coq system. This extension consists of an extension to the Coq language of script, and of a set of libraries, originating from the formal proof of the Four Color theorem. This tutorial proposes a guided tour in some of the basic libraries distributed in the Ssreflect package. It focuses on the application of the small scale reflection methodology to the formalization of finite objects in intuitionistic type theory.
main-rr.pdf (769.04 Ko) Télécharger le fichier
inria-00515548 , version 1 (07-09-2010)
inria-00515548 , version 2 (22-09-2010)
inria-00515548 , version 3 (02-11-2010)
inria-00515548 , version 4 (13-01-2011)
  • HAL Id : inria-00515548 , version 4
Georges Gonthier, Assia Mahboubi. An introduction to small scale reflection in Coq. Journal of Formalized Reasoning, 2010, 3 (2), pp.95-152. ⟨inria-00515548v4⟩
765 Consultations
2001 Téléchargements
