inria-00516020, version 1
Formal Modeling and Verification of Services Managements for Pervasive Computing Environment
Hai Wan
1Zoé Drey 2Zhiyang You 1Liu Liu 1
The 7th International Conference on Service Systems and Service Management (2010)
Résumé : Various forms of pervasive computing environments are being deployed in an increasing number of areas including hospitals, homes and military settings. Entities in this environment provide rich functionalities (i.e. services). How to organize these heterogeneous and distributed entities to deliver user-defined services is challenging. Pantagruel is an approach to integrate a taxonomical description of a pervasive computing environment into a visual programming language. A taxonomy describes the relevant entities of a given pervasive computing area and serves as a parameter to a sensor-controller-actuator develop- ment paradigm. The orchestration of area-specific entities is supported by high-level constructs, customized with respect to taxonomical information. Pantagruel is also a language that describes and manages services. Further more, Pantagruel can be viewed as a high level service contract between the service designer and the program implementer. This paper presents a for- malization of Pantagruel, both its syntax and semantics. Four kinds of static properties are stated based on the formalization. Predicate abstraction based algorithms are designed to verify the properties.
- 1 : FORMES (LIAMA)
- INRIA – Tsinghua University / Beijing – LIAMA
- 2 : PHOENIX (INRIA Bordeaux - Sud-Ouest)
- INRIA – Université Sciences et Technologies - Bordeaux I – École Nationale Supérieure d'Électronique, Informatique et Radiocommunications de Bordeaux (ENSEIRB) – CNRS : UMR
- Domaine : Informatique/Systèmes embarqués
- inria-00516020, version 1
- http://hal.inria.fr/inria-00516020
- oai:hal.inria.fr:inria-00516020
- Contributeur : Hai Wan
- Soumis le : Mardi 8 Mars 2011, 07:00:42
- Dernière modification le : Mardi 8 Mars 2011, 07:00:42
Documents associés
Exporter
