Families of explicitly isogenous Jacobians of variable-separated curves - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue LMS Journal of Computation and Mathematics Année : 2011
We construct six infinite series of families of pairs of curves (X,Y) of arbitrarily high genus, defined over number fields, together with an explicit isogeny from the Jacobian of X to the Jacobian of Y splitting multiplication by 2, 3, or 4. For each family, we compute the isomorphism type of the isogeny kernel and the dimension of the image of the family in the appropriate moduli space. The families are derived from Cassou--Noguès and Couveignes' explicit classification of pairs (f,g) of polynomials such that f(x_1) - g(x_2) is reducible.
isogenies.pdf (277.13 Ko) Télécharger le fichier
README (867 B) Télécharger le fichier
degree-11.m (5.78 Ko) Télécharger le fichier
degree-13.m (14.67 Ko) Télécharger le fichier
degree-15.m (10.44 Ko) Télécharger le fichier
degree-21.m (16.21 Ko) Télécharger le fichier
degree-31.m (95.21 Ko) Télécharger le fichier
degree-7.m (4.52 Ko) Télécharger le fichier
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
inria-00516038 , version 1 (08-09-2010)
Benjamin Smith. Families of explicitly isogenous Jacobians of variable-separated curves. LMS Journal of Computation and Mathematics, 2011, 14, pp.179-199. ⟨10.1112/S1461157010000410⟩. ⟨inria-00516038⟩
377 Consultations
244 Téléchargements
