Hierarchy Accelerated Stochastic Collision Detection - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2004
In this paper we present a new framework for col- lision and self-collision detection for highly de- formable objects such as cloth. It permits to effi- ciently trade off accuracy for speed by combining two different collision detection approaches. We use a newly developed stochastic method, where close features of the objects are found by track- ing randomly selected pairs of geometric primi- tives, and a hierarchy of discrete oriented polytopes (DOPs). This bounding volume hierarchy (BVH) is used to narrow the regions where random pairs are generated, therefore fewer random samples are nec- essary. Additionally the cost in each time step for the BVH can be greatly reduced compared to pure BVH-approaches by using a lazy hierarchy update. For the example of a cloth simulation framework it is experimentally shown that it is not necessary to respond to all collisions to maintain a stable simu- lation. Hence, the tuning of the computation time devoted to collision detection is possible and yields faster simulations.
HAST.pdf (641.11 Ko) Télécharger le fichier
Format : Figure, Image
inria-00516887 , version 1 (13-09-2010)
  • HAL Id : inria-00516887 , version 1
Stephan Kimmerle, Matthieu Nesme, François Faure. Hierarchy Accelerated Stochastic Collision Detection. 9th International Workshop on Vision, Modeling, and Visualization, VMV 2004, Nov 2004, Stanford, California, United States. ⟨inria-00516887⟩
558 Consultations
341 Téléchargements
