Real-time Simulation of Self-collisions for Virtual Intestinal Surgery - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2003
The context of this research is the development of a pedagogical surgery simulator for colon cancer removal. More precisely, we would like to simulate the gesture which consists of moving the small intestine folds away from the cancerous tissues of the colon. This paper presents a method for animating the small intestine and the mesentery (the tissue that connects it to the main vessels) in real-time, thus enabling user-interaction through virtual surgical tools during the simulation. The main issue that we solve here is the real-time processing of multiple collisions and self-collisions that occur between the intestine and mesentery folds.
autoCollisions.pdf (371.42 Ko) Télécharger le fichier
film2.mpg (16.71 Mo) Télécharger le fichier
film5.mpg (16.75 Mo) Télécharger le fichier
film6.mpg (15.24 Mo) Télécharger le fichier
mesentere.mpg (3.21 Mo) Télécharger le fichier
presentation-is4tm.pdf (487.99 Ko) Télécharger le fichier
presentation-is4tm.ppt (1.58 Mo) Télécharger le fichier
Format : Figure, Image
Format : Autre
Format : Autre
Format : Vidéo
Format : Autre
Format : Autre
Format : Autre
inria-00516889 , version 1 (13-09-2010)
  • HAL Id : inria-00516889 , version 1
Laks Raghupathi, Vincent Cantin, François Faure, Marie-Paule Cani. Real-time Simulation of Self-collisions for Virtual Intestinal Surgery. International Symposium on Surgery Simulation and Soft Tissue Modeling, IS4TM 2003, Jun 2003, Juan-Les-Pins, France. pp.15--26. ⟨inria-00516889⟩
1088 Consultations
5021 Téléchargements
