FDI in Multivariate Process with Naive Bayesian Network in the Space of Discriminant Factors - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Quality Assurance Année : 2009
The Naïve Bayesian Network (NBN) classifier is an optimal classifier(in the sense of minimal classification error rate) in the case of independent descriptors or variables. The presence of dependencies between variables generally reduce his efficiency. In this article, we are proposing a new classification method named Naïve Bayesian Network in the Space of Discriminants Factors (NBNSDF) which is based on the use of the NBN in the space of discriminants factors issue from a discriminant analysis. The discriminants factors are not correlated letting very efficient the use of the NBN. We found on simulated data that the NBNSDF method better detects and isolates faults in multivariate processes than the NBN in the case of strongly correlated variables.
tiplica09.pdf (172.51 Ko) Télécharger le fichier
inria-00517110 , version 1 (13-09-2010)
  • HAL Id : inria-00517110 , version 1
Teodor Tiplica, Sylvain Verron, Abdessamad Kobi, Iulian Nastac. FDI in Multivariate Process with Naive Bayesian Network in the Space of Discriminant Factors. Quality Assurance, 2009, 57. ⟨inria-00517110⟩
Collections
UNIV-ANGERS
284 Consultations
121 Téléchargements
