Physical cloth simulation on a PC cluster - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2002
Cloth simulation is of major interest in 3D animation, as it allows the realistic modeling of dressed humans. The goal of our work is to decrease computation time in order to obtain real time dynamics animation. This paper describes a cloth simulation and addresses the problem of parallelizing the implicit time integration and to couple a parallel execution with a standard visualization. We believe that this work could benefit to other applications based on a conjugate gradient solution and other applications of PC clusters.
paper.pdf (187.79 Ko) Télécharger le fichier
Format : Figure, Image
inria-00517244 , version 1 (14-09-2010)
  • HAL Id : inria-00517244 , version 1
Florence Zara, François Faure, Jean-Marc Vincent. Physical cloth simulation on a PC cluster. 4h Eurographics Workshop on Parallel Graphics and Visualization, Sep 2002, Blaubeuren, Germany. ⟨inria-00517244⟩
308 Consultations
203 Téléchargements
