An Interactive Forest - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2001
We present a prototype of a forest in which a video game player can move and interact physically with the trees. The trees are procedurally built on-the-fly at each redraw. Two animation approaches are combined: a procedural method which handles most of the trees efficiently, and a physically-based method which allows user interaction with the trees. The physically-based method is dynamically applied only where needed. Physical data is computed only where the physical method is applied, and deleted afterwards. Smooth transitions between animation methods are performed. Levels of detail are used for rendering and for procedural animation. Our method allows the display and the animation, including user action, of a 256-tree forest at interactive rates.
DCF01.pdf (200.68 Ko) Télécharger le fichier
force.avi (11.31 Mo) Télécharger le fichier
mix.avi (2.86 Mo) Télécharger le fichier
phys.avi (4.88 Mo) Télécharger le fichier
procauto.avi (25.31 Mo) Télécharger le fichier
procman.avi (3.92 Mo) Télécharger le fichier
Format : Figure, Image
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
inria-00517590 , version 1 (14-09-2010)
  • HAL Id : inria-00517590 , version 1
Thomas Di Giacomo, Stéphane Capo, François Faure. An Interactive Forest. Eurographics Workshop on Computer Animation and Simulation (EGCAS), Sep 2001, Manchester, United Kingdom. pp.65-74. ⟨inria-00517590⟩
438 Consultations
490 Téléchargements
