Computational analysis of an aortic valve jet with Lagrangian coherent structures - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Chaos: An Interdisciplinary Journal of Nonlinear Science Année : 2010
Important progress has been achieved in recent years in simulating the fluid-structure interaction around cardiac valves. An important step in making these computational tools useful to clinical practice is the development of postprocessing techniques to extract clinically relevant information from these simulations. This work focuses on flow through the aortic valve and illustrates how the computation of Lagrangian coherent structures can be used to improve insight into the transport mechanics of the flow downstream of the valve, toward the goal of aiding clinical decision making and the understanding of pathophysiology.
2010_shadden_astorino_gerbeau.pdf (1.63 Mo) Télécharger le fichier
inria-00517786 , version 1 (16-09-2010)
Shawn C. Shadden, Matteo Astorino, Jean-Frédéric Gerbeau. Computational analysis of an aortic valve jet with Lagrangian coherent structures. Chaos: An Interdisciplinary Journal of Nonlinear Science, 2010, 20, pp.017512-1. ⟨10.1063/1.3272780⟩. ⟨inria-00517786⟩
240 Consultations
517 Téléchargements
