Stable Inverse Dynamic Curves - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue ACM Transactions on Graphics Année : 2010
2d animation is a traditional but fascinating domain that has recently regained popularity both in animated movies and video games. This paper introduces a method for automatically converting a smooth sketched curve into a 2d dynamic curve at stable equilibrium under gravity. The curve can then be physically animated to produce secondary motions in 2d animations or simple video games. Our approach proceeds in two steps. We first present a new technique to fit a smooth piecewise circular arcs curve to a sketched curve. Then we show how to compute the physical parameters of a dynamic rod model (super-circle) so that its stable rest shape under gravity exactly matches the fitted circular arcs curve. We demonstrate the interactivity and controllability of our approach on various examples where a user can intuitively setup efficient and precise 2d animations by specifying the input geometry.
stableInverseDynamicCurvesSA.pdf (3.75 Mo) Télécharger le fichier
Format : Figure, Image
inria-00518204 , version 1 (16-09-2010)
Alexandre Derouet-Jourdan, Florence Bertails-Descoubes, Joëlle Thollot. Stable Inverse Dynamic Curves. ACM Transactions on Graphics, 2010, 29 (6), pp.137-137:9. ⟨10.1145/1866158.1866159⟩. ⟨inria-00518204⟩
298 Consultations
685 Téléchargements
