Approximate computation of curves on B-spline surfaces - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Computer-Aided Design Année : 2008
Curves on surfaces play an important role in computer-aided geometric design. Because of the considerably high degree of exact curves on surfaces, approximation algorithms are preferred in CAD systems. To approximate the exact curve with a reasonably low degree curve which also lies completely on the B-spline surface, an algorithm is presented in this paper. The Hausdorff distance between the approximate curve and the exact curve is controlled under the user-specified distance tolerance. The approximate curve is ɛT –G1 continuous, where ɛT is the user-specified angle tolerance. Examples are given to show the performance of our algorithm.
Yi-JunYang2008a.pdf (2.08 Mo) Télécharger le fichier
inria-00518325 , version 1 (17-09-2010)
Yi-Jun Yang, Song Cao, Jun-Hai Yong, Hui Zhang, Jean-Claude Paul, et al.. Approximate computation of curves on B-spline surfaces. Computer-Aided Design, 2008, 40 (2), pp.223-234. ⟨10.1016/j.cad.2007.10.011⟩. ⟨inria-00518325⟩
180 Consultations
245 Téléchargements
