Computing the minimum distance between a point and a NURBS curve - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Computer-Aided Design Année : 2008
A new method is presented for computing the minimum distance between a point and a NURBS curve. It utilizes a circular clipping technique to eliminate the curve parts outside a circle with the test point as its center point. The radius of the elimination circle becomes smaller and smaller during the subdivision process. A simple condition for terminating the subdivision process is provided, which leads to very few subdivision steps in the new method. Examples are shown to illustrate the efficiency and robustness of the new method.
Xiao-DiaoChen2008b.pdf (970.28 Ko) Télécharger le fichier
inria-00518359 , version 1 (17-09-2010)
Xiao-Diao Chen, Jun-Hai Yong, Guozhao Wang, Jean-Claude Paul, Gang Xu. Computing the minimum distance between a point and a NURBS curve. Computer-Aided Design, 2008, 40 (10-11), pp.1051-1054. ⟨10.1016/j.cad.2008.06.008⟩. ⟨inria-00518359⟩
268 Consultations
3230 Téléchargements
