Computing minimum distance between two implicit algebraic surfaces - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Computer-Aided Design Année : 2006
The minimum distance computation problem between two surfaces is very important in many applications such as robotics, CAD/CAM and computer graphics. Given two implicit algebraic surfaces, a new method based on the offset technique is presented to compute the minimum distance and a pair of points where the minimum distance occurs. The new method also works where there are an implicit algebraic surface and a parametric surface. Quadric surfaces, tori and canal surfaces are used to demonstrate our new method. When the two surfaces are a general quadric surface and a surface which is a cylinder, a cone or an elliptic paraboloid, the new method can produce two bivariate equations where the degrees are lower than those of any existing method.
Xiao-DiaoChen2006a.pdf (1.12 Mo) Télécharger le fichier
inria-00518397 , version 1 (17-09-2010)
Xiao-Diao Chen, Jun-Hai Yong, Guo-Qin Zheng, Jean-Claude Paul, Jia-Guang Sun. Computing minimum distance between two implicit algebraic surfaces. Computer-Aided Design, 2006, 38 (10), pp.1053-1061. ⟨10.1016/j.cad.2006.04.012⟩. ⟨inria-00518397⟩
99 Consultations
2677 Téléchargements
