Standardization of Rational Bézier Surfaces - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Computer Aided Design & Computer Graphics Année : 2007
The sufficient and necessary condition for the existence of linear Möbius transformations that can standardize the rational Bézier surfaces is given based on Möbius reparameterization theorem. To obtain the standard form of an arbitrary cubic rational Bézier surface, we then present a quadratic reparameterization algorithm to reparameterize the surface so that all the corner weights of the surface are equal to one. Examples are included to show the performance of the new method.
Yi-JunYang2007a.pdf (438.18 Ko) Télécharger le fichier
inria-00519199 , version 1 (18-09-2010)
  • HAL Id : inria-00519199 , version 1
  • PRODINRA : 246816
Yi-Jun Yang, Jun-Hai Yong. Standardization of Rational Bézier Surfaces. Journal of Computer Aided Design & Computer Graphics, 2007. ⟨inria-00519199⟩
291 Consultations
141 Téléchargements
