Exploitation de la monotonie des fonctions dans la propagation de contraintes sur intervalles
We propose a new interval constraint propagation algorithm, called MOnotonic Hull Consistency (Mohc), that exploits monotonicity of functions. The propagation is standard, but the Mohc-Revise procedure, used to filter/contract the variable domains w.r.t. an individual constraint, uses monotonic versions of the classical HC4- Revise and BoxNarrow procedures. Mohc-Revise appears to be the first adaptive revise procedure ever proposed in constraint programming. Also, when a function is monotonic w.r.t. every variable, Mohc-Revise is proven to compute the optimal/ sharpest box enclosing all the solutions of the corresponding constraint (hull consistency). Very promising experimental results suggest that Mohc has the potential to become an alternative to the state-of-the-art HC4 and Box algorithms.
Intelligence artificielle [cs.AI]
Origine : Accord explicite pour ce dépôt
