Hereditary Substitutions for Simple Types, Formalized - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We analyze a normalization function for the simply typed lambda-calculus based on hereditary substitutions, a technique developed by Pfenning et al. The normalizer is implemented in Agda, a total language where all programs terminate. It requires no termination proof since it is structurally recursive which is recognized by Agda's termination checker. Using Agda as an interactive theorem prover we establish that our normalization function precisely identifies beta-eta-equivalent terms and hence can be used to decide beta-eta-equality. An interesting feature of this approach is that it is clear from the construction that beta-\eta-equality is primitive recursive.
msfp10.pdf (175.84 Ko) Télécharger le fichier
inria-00520606 , version 1 (20-03-2012)
  • HAL Id : inria-00520606 , version 1
Chantal Keller, Thorsten Altenkirch. Hereditary Substitutions for Simple Types, Formalized. MSFP - Third Workshop on Mathematically Structured Functional Programming - 2010, Sep 2010, Baltimore, United States. ⟨inria-00520606⟩
216 Consultations
915 Téléchargements
