New lower bounds for bin packing problems with conflicts - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue European Journal of Operational Research Année : 2010
The bin packing problem with conflicts (BPC) consists of minimizing the number of bins used to pack a set of items, where some items cannot be packed together in the same bin due to compatibility restrictions. The concepts of dual-feasible functions (DFF) and data-dependent dual-feasible functions (DDFF) have been used in the literature to improve the resolution of several cutting and packing problems. In this paper, we propose a general framework for deriving new DDFF as well as a new concept of generalized data-dependent dual-feasible functions (GDDFF), a conflict generalization of DDFF. The GDDFF take into account the structure of the conflict graph using the techniques of graph triangulation and tree-decomposition. Then we show how these techniques can be used in order to improve the existing lower bounds.
inria-00522668 , version 1 (01-10-2010)
Ali Khanafer, François Clautiaux, El-Ghazali Talbi. New lower bounds for bin packing problems with conflicts. European Journal of Operational Research, 2010, 2 (206), pp.281-288. ⟨10.1016/j.ejor.2010.01.037⟩. ⟨inria-00522668⟩
137 Consultations
0 Téléchargements
