Mesh repair with user-friendly topology control - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Computer-Aided Design Année : 2011
Limitations of current 3D acquisition technology often lead to polygonal meshes exhibiting a number of geometrical and topological defects which prevent them from widespread use. In this paper we present a new method for model repair which takes as input an arbitrary polygonal mesh and outputs a valid two-manifold triangle mesh. Unlike previous work, our method allows users to quickly identify areas with potential topological errors and to choose how to fix them in a user-friendly manner. Key steps of our algorithm include the conversion of the input model into a set of voxels, the use of morphological operators to allow the user to modify the topology of the discrete model, and the conversion of the corrected voxel set back into a two-manifold triangle mesh. Our experiments demonstrate that the proposed algorithm is suitable for repairing meshes of a large class of shapes.
mesh_repair.pdf (2.45 Mo) Télécharger le fichier
Format : Figure, Image
inria-00523005 , version 1 (04-10-2010)
Franck Hétroy, Stéphanie Rey, Carlos Andujar, Pere Brunet, Alvar Vinacua. Mesh repair with user-friendly topology control. Computer-Aided Design, 2011, 43 (1), pp.101-113. ⟨10.1016/j.cad.2010.09.012⟩. ⟨inria-00523005⟩
629 Consultations
1296 Téléchargements
