Using models of dynamics for large displacement estimation on noisy acquisitions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2010
The paper discusses the issue of motion estimation on noisy images displaying large displacements, due to high velocity values. ``Noisy'' means that the data contain either missing acquisitions on isolated points, regions, frames or noisy measures. Assuming the dynamics is partially accessible from heuristics and modeled, the objective is to include this knowledge in the computation of the solution even if large displacements occur from one frame to the next one and if the data are noisy. This is performed by Data Assimilation techniques which simultaneously solve an evolution equation and an observation equation. The evolution equation includes the partial knowledge on the dynamics. The observation equation describes the transport of image brightness and is written in a non-linear form in order to better characterize large displacements. The assimilation method is a weak 4D-Var algorithm, in which each component of the Data Assimilation system is associated to an error. We prove that the observation covariance matrix can be used to discard the noisy data during the computation of the solution letting the evolution equation estimate motion from adjacent frames on these pixels. The method is quantified on synthetic data and illustrated on oceanographic satellite images.
Cet article traite du problème de l'estimation du mouvement sur des données bruitées montrant de grands déplacements engendrés par des vitesses élevées. Par données ``bruitées'' nous entendons des données qui contiennent à la fois des informations manquantes en des points isolés, des régions ou des plans image entiers et du bruit de mesure. En supposant que la dynamique de la séquence d'image peut être décrite par des heuristiques, le but est d'inclure cette connaissance dans le calcul de la solution et cela malgré la présence de vitesses élevées. Ceci est réalisé par assimilation de données en résolvant simultanément une équation d'évolution et une équation d'observation. L'équation d'évolution décrit imparfaitement la dynamique. L'équation d'observation décrit le transport de la luminosité par la vitesse et elle est écrite sous sa forme non linéaire afin de prendre en compte les grands déplacements. La méthode d'assimilation de données utilisée ici est le ``4DVar'' dans sa formulation faible et pour laquelle chaque composante du système à résoudre est associée à une erreur. Nous montrons que la matrice de covariance associée au modèle d'observation peut être utilisée pour éliminer du calcul de la solution les pixels qui contiennent une information bruitée. Pour ces pixels, l'équation d'évolution permet alors de calculer une solution admissible. La méthode proposée est évaluée sur des données synthétiques et appliquée sur des données océanographiques contenant de véritables données manquantes.
RR-7408.pdf (654.73 Ko) Télécharger le fichier
inria-00523625 , version 1 (06-10-2010)
  • HAL Id : inria-00523625 , version 1
Dominique Béréziat, Isabelle Herlin. Using models of dynamics for large displacement estimation on noisy acquisitions. [Research Report] RR-7408, INRIA. 2010, pp.18. ⟨inria-00523625⟩
187 Consultations
63 Téléchargements
