Exploiting loops in the graph of trifocal tensors for calibrating a network of cameras - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
A technique for calibrating a network of perspective cameras based on their graph of trifocal tensors is presented. After estimating a set of reliable epipolar geometries, a parameterization of the graph of trifocal tensors is proposed in which each trifocal tensor is encoded by a 4-vector. The strength of this parameterization is that the homographies relating two adjacent trifocal tensors, as well as the projection matrices depend linearly on the parameters. A method for estimating these parameters in a global way benefiting from loops in the graph is developed. Experiments carried out on several real datasets demonstrate the efficiency of the proposed approach in distributing errors over the whole set of cameras.
inria-00523988 , version 1 (06-10-2010)
Jérôme Courchay, Arnak S. Dalalyan, Renaud Keriven, Peter Sturm. Exploiting loops in the graph of trifocal tensors for calibrating a network of cameras. ECCV 2010 - European Conference on Computer Vision, Sep 2010, Heraklion, Greece. pp.85-99, ⟨10.1007/978-3-642-15552-9_7⟩. ⟨inria-00523988⟩
265 Consultations
0 Téléchargements
